Batch processing - close dialog option issue and suggestion
Dreamer
Post by Dreamer »
Batch processing > drop down menu with "No action", "Open output folder wit XnView" / "...Explorer" is truncated in many languages, Czech, Slovak, German, even in French!
It's also not clear what these options mean, especially "no action", So I suggest to change it...
From this...
[x] Close dialog after conversion [No action [v] ]
To this:
After conversion:
[x] Close dialog
(o) Do not open output folder
( ) Open output folder in XnView
( ) Open output folder in Explorer
Placement and form might be different, I don't know if radio buttons are better than drop down menu...
Dreamer
Danny
Re: Batch processing - close dialog option issue and suggestion
Post by Danny »
I suggest this:
[x] Close dialog after conversion and
The bold part is new. The dropdown to the right stays exactly the same.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
Dreamer
Post by Dreamer »
OK, but if that first option will be disabled??
Dreamer
JohnFredC
Post by JohnFredC »
Dreamer wrote:OK, but if that first option will be disabled??
Correct.
"And" would be logically wrong in that specific case. "And/or" is the correct sense for a generic label, but awkward... I conclude no conjunction is necessary.
Good suggestion otherwise. Support+
John
Danny
Post by Danny »
I see it as one line or sentence. If you uncheck it at the front, the whole thing is disabled.
Dreamer
Post by Dreamer »
Danny wrote:I see it as one line or sentence. If you uncheck it at the front, the whole thing is disabled.
OK, but what if someone wants the other option and don't want the first one??
Dreamer
Danny
Post by Danny »
Does "Open folder in XNv" even work? It's a modal window, meaning that program window behind it is inaccessible until you close the dialog.
edit: Yes, it does work - i didn't notice that this was possible now. And, in fact, it only works after a process has been finished.
Well, in this case something could be done, yes. I don't like the "Do not open output folder" option, though. You have to think about that statement, even more because it's using negation ("do not do this"), which is bad for text comprehension. "Do nothing", kind like it already is, works better IMO.
Dreamer
Post by Dreamer »
OK, but this is not good either:
"After conversion: [x] Close dialog ...and... (o) "Do nothing""
Therefore I've suggested "Do not open output folder".
Dreamer
Danny
Post by Danny »
I've already said why i don't like that.
