Folder Pane doesn't render unicode folder name.
sandthorn
Unicode folder names are not rendered correctly. Non-western characters appear as white rectangles.
Even though "location bar" can render unicode correctly.
Thanks,
Sand
Thanks,
Sand
Re: Folder Pane doesn't render unicode folder name.
Linux? Folder pane doesn't show correctly unicode folder name, and in thumbnail view?
sandthorn
Thumbnail View is able to render unicode character.
Folder Pane, Favorite Pane, Category Pane all are unable to render unicode string.
While "Location Bar", "Thumbnail View", "Add to Favoite Dialog" are able to render unicode character.
[Windows 7 32-bit]
[Windows 7 32-bit]
Could you post a screenshot?
sandthorn
Screenshot
And with thumbnail view?
sandthorn
Here we go.
And a screenshot if you are in Wallpaper folder, and if you activate folder in thumbnail view?
I have no problem with cyrillic folder name.
Is it possible to send me a file/folder?
sandthorn
"Tooltip" is not rendered correctly in thumbnail view.
Very strange, here is on my Xp
sandthorn
Let others with 7 or vista try this out then.
Perhaps 7 might change some property of Windows API Font? I don't know.
Anyway, XnView 1.97 displays unicode characters correctly though.
Ok, i've tried on 7, and yes your folder name is not correctly rendered. But the cyrillic is ok... Very strange...sandthorn wrote:Let others with 7 or vista try this out then.
sandthorn
This is just the morning of 7. I'm certained you will find the way to fix that soon.
Thanks,
Sand
P.S. Please also investigate DEP crash issue on
http://newsgroup.xnview.com/viewtopic.php?f=60&t=19227
Thanks,
Sand
It's a bug in QT toolkitsandthorn wrote:This is just the morning of 7. I'm certained you will find the way to fix that soon.
Conqueror
Was this problem ever fixed? I am getting the same problem. I can't open a folder in XnView which contains unicode (e.g. Arabic) characters.
I can't use Windows browser (which is set to open XnView by default) to open a file which has Arabic characters in it's path. I get an error which shows question marks in the path where non-English characters should be.
I am using windows 7 64 bit.
