Changing the window color.. any way to do this?
Plug-ins, add-ons, skins, icons, templates and other downloads. Contributions are welcome.
LfmC
Post by LfmC »
I've edited most of the Xnview's interface, made som cool black folders and background resembling my old picture viewer ACDsee... but whatever I do, I can't seem to find a way to edit the windows color itself.
Is there any way to do this, other than changing the windows theme to a black one?
(Win7 x64, Latest Xnview)
Example:
P.S. If anyone has a link to the Matte DeLuxe (Sasha Rio) toolbar icons skin, I'd appreciate it. Can't seem to find it anywhere on the forum.
Thanks
Re: Changing the window color.. any way to do this?
LfmC wrote:If anyone has a link to the Matte DeLuxe (Sasha Rio) toolbar icons skin, I'd appreciate it. Can't seem to find it anywhere on the forum.
Contribution » Customization » Update Skin "Matte DeLuxe" for XnView 1.91.6
LfmC
Post by LfmC »
Thanks, but I tried that one. Dead link :(
LfmC, have you considered sending sashario a private message asking him to upload a new version (updated from v2 to v4) of his skin?
srr
Post by srr »
hello! I've been looking for this too as I've changed operating systems and updated XnView in the process - I'll upload my (old) version of the skin for you in just a mo.
srr
Post by srr »
Right! Here it is: Matte DeLuxe (old, but works fine on current versions of XnView, don't know what's missing yet as it probably relates to features I don't use!)
LfmC
Post by LfmC »
srr wrote:Right! Here it is: Matte DeLuxe (old, but works fine on current versions of XnView, don't know what's missing yet as it probably relates to features I don't use!)
Thanks m8 :)
Now that leaves only the question of changing the color of the window from windows default to another color... anyone know if this is possible and how to do it?
:arrow: LfmC
:) Hello !
• From Options (F12) >> Thumbnail you can change the background colour of the board of thumb nails,
similarly in Options >> Preview the one of the Preview BG…
- But AFAIK you can't change the colour of the tree dock BG, which comes from the system…
:mrgreen: KR
ckv ([url=http://newsgroup.xnview.com/viewtopic.php?p=73420#p73420]UI-less Settings[/url]) wrote:
ToolbarBackColor:
Changes the backround colour of the toolbar.
Value: Raw colour (integer) or fromated colour string
See also UseToolbarBackColor setting
Broken ==> http://newsgroup.xnview.com/viewtopic.php?t=17005
UseToolbarBackColor:
When enabled, XnView uses the custom toolbar backround colour specified by ToolbarBackColor option.
Value: Boolean (1/0), disabled by default
See also ToolbarBackColor setting
XnView Tweak UI is graphical user interface build around the ui-less settings in xnview. Currently about half of the ui-less settings are supported, but the bold goal is to add support for all of them.
