I get the following error when using v5.6 command:
D:\apps\nConvert>nconvert -out jpeg waterwheel.ai
** NCONVERT v5.60 (c) 1991-2010 Pierre-E Gougelet (Feb 26 2010/10:09:43) **
Version for Windows NT/9x/2000/Xp/Vista (All rights reserved)
** This is a freeware software (for non commercial use)
Error: Can't create file (waterwheel.ai)
This command is pretty basic, and it works under the previous version 5.54
I'm running this on Microsoft Windows Server 2003 R2
nConvert v5.6 command line error
Re: nConvert v5.6 command line error
Ok, right a bug. Add -overwrite
ArdithHVernon
Hi Pierre and thanks a lot for XnView and NConvert.
The -overwrite is exactly what I needed, and unfortunately it was missing from the 5.60 -help (but it's now in the 5.62 -help).
If it's easy, it would be nice to display something like "Error: Can't overwrite file (waterwheel.ai). Use -overwrite to overwrite it." instead of simply "Error: Can't create file (waterwheel.ai)".
Yes right, i'll change the message...ArdithHVernon wrote:Hi Pierre and thanks a lot for XnView and NConvert.
