Export with categoris
valhall
Post by valhall »
Is there any way too be able too use the categories on two computers in a network .
I am not too fond over that i maybe have too do all the categories again on my second computer. :| I am using an extern disk for accessing my photos, witch I have copy My Pictures too.
this is probably not in the correct topic, bu some nice person maybe is kind too move it if necessary. :wink:
Hppy Easter Too ALL :mrgreen:
foxyshadis
Re: Export with categoris
Post by foxyshadis »
If you have them on EXACTLY the same network drives and paths on both PCs, it's really really simple: Just copy %appdata%\XnView\category.db to the second PC. Copy it back and forth when you update it, or get a syncronization program to do it for you. (%appdata% expands to C:\Users\<name>\AppData\Roaming on Vista/7, or C:\Documents and Settings\<name>\Application Data on 2k/XP.)
If they're not, you'd have to use a custom script to keep them in sync, which gets nasty pretty quickly.
