Hello ,
We have Problems with the Filesize of the output-picture from nconvert.
The output picture have about the 3,5 higher filesize of the input picture .
here the Batch command with nconvert.
nconvert" -q 100 -npcd 2 -size 256x256+0 -ctype grey -corder inter -out jpeg -v -o "\\Servername\Share\output-Picture Input-Picture
Why ist the Filesize so bigger than the input-pictures ?
We use the nconvert Version v5.31
Thanks for Reply
nconvert with great output-Filesize
Re: nconvert with great output-Filesize
it's -q 100
hawk_vs
Hello Pierre,
We used -q 100 and became the bigger results of the picturesize .
Without the -q 100 at the commandline ,nconvert should use also the -q 100 as default .
Or is this wrong and nconvert use another defaultvalue?
Here is the Filesize now 1/4 of the original input picture.
Where are the difference and Why ?
Kind Regards
Kind Regards
By default the quality used is 80
