PCL-Format: writing, but not reading?
Peter2
Post by Peter2 »
The page which displays the file formats known by XnView
http://www.xnview.com/de/formats.html
tells me that PCL can be written, but not read.
Is this true???
Peter
Re: PCL-Format: writing, but not reading?
Peter2 wrote: Is this true???
Yes, it's not easy to read PCL
Peter2
Post by Peter2 »
xnview wrote:Yes, it's not easy to read PCL
That is clear - but it can write it? (Or "print to file" with PCL printer?)
Peter
eL_PuSHeR
Post by eL_PuSHeR »
According to my tests, it doesn't work properly yet.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
Peter2
Post by Peter2 »
eL_PuSHeR wrote:According to my tests, it doesn't work properly yet.
What? What works - and what not?
Peter
eL_PuSHeR
Post by eL_PuSHeR »
I have saved some PCL files and they do not print properly on my HP Laserjet 1200 printer.
Intel i7 5960X
8 GB DDR4 (2100)
