Hi:)
Someone can tell me why the thumbnails have different size? I post here an image about the problem
http://img697.imageshack.us/img697/570/immaginevga.jpg
I want have all the thumbnails showed in bigger mode
Thank's
thumbnails problem, different image size
Re: thumbnails problem, different image size
Some of them use embedded thumbnail, please enable option/Thumbnail>Create from original...
otreus
thank's but no luck
I have post here a screeshothttp://img571.imageshack.us/img571/1162/immagineyj.jpg
marsh
otreus, Try also Menu... View>Rebuild thumnails (this will update the cache)
otreus
perfect, many thank's
Last help, why when I close XnView I see at the top of the program that show all the name of the image that I have see in the last session? I think XnView remember and have open a tab for every pic that I have see and when I close the program the tab are closed. Can I didable this option for speeed-up the program?
marsh
If you want to view/edit one image at a time, there is: Options>View>[x]Only one window view opened.
otreus
Thank's, is exactly what I want
