Hi
i have a question about have raw thumbs in the explorer in Windows 7 and XP sp2/3
well for w7 there are for example the canon raw codec , but they are bloody slow
i did not find a shell integration fast and update
does XnView Shell Extension Setup v2.90 let me show raw thumbs file in explorer just like jpg?
i mean is there a way to use XnView Shell Extension Setup v2.90 to have raw thumbnails in my explorer for w7 and xp?
if not ,is there an good and update alternative?
thanks
have a great day
raw thumbs in windows 7 and xp,can i do it?
Re: raw thumbs in windows 7 and xp,can i do it?
No XnView Shell Extension Setup show the thumb in context menu.
You can try SageThumbs
