[Solved] Batch-processing: ESC cancels all
Peter2
Post by Peter2 »
If I cancel a batch process with the "cancel-button" it cancels all: the "processing dialogue" and the "main configuration dialogue". This could be very hard if i.e. the file-selection was rather complicated ...
Better: "Cancel" only cancels the batch-process, but not the configuration dialogue.
Peter
Peter2
Re: Batch-processing: ESC cancels all
Post by Peter2 »
Push up ..
Peter
When you press Cancel in the progress dialog, 'batch convert' dialog is closed??
Peter2
Post by Peter2 »
xnview wrote:When you press Cancel in the progress dialog, 'batch convert' dialog is closed??
If I remember correctly - yes, indeed. But it was in last July with an older version (1.97.6? or something ...)
Now it seem to be correct - both "Cancel"-button and "Esc" on keyboard, but now while testing sometimes XnView lost its focus and another software came to front. But after some repetitions it happened no more ... :?: :?: :?:
Peter
marsh
Post by marsh »
Peter
With batch convert option '[x]Close dialog after conversion', it also closes dialog when it is interrupted by <ESC>
Peter2
Post by Peter2 »
marsh wrote:With batch convert option '[x]Close dialog after conversion', it also closes dialog when it is interrupted by <ESC>
OK, this seem to be trick - but we could discuss if its a bug or a feature. IMHO ESC should always return to the dialogue.
Peter
marsh
Post by marsh »
I agree that cancelling conversion should return to the dialog. It is unusual for a key to have more than one action (and for example, I wouldn't want halting building of thumbnails to also close program). Better to have 'close dialog' disabled by default for the reasons you mentioned also.
marsh
Post by marsh »
Works perfectly here, v1.98b1. Selection is remembered also. Thanks Pierre.
Peter2
Post by Peter2 »
marsh wrote:Works perfectly here, v1.98b1. Selection is remembered also. Thanks Pierre.
Confirmed.
Peter
