Different effects of same picture
Xanderway
Post by Xanderway »
The screen shot that I got in XnView is
But in windows, it looks like
Can you see the difference?
The seconde one looks naturelly. Why?
marsh
Re: Different effects of same picture
Post by marsh »
The filename shown on link (jpg) doesn't match image format, GIF. Which did you want to use?
Xanderway
Post by Xanderway »
The format is jpg
Xanderway wrote:The format is jpg
You have difference between the 2 files in XnView?
DOS386
Post by DOS386 »
Xanderway wrote:Can you see the difference?
YES.
The upper image apparently has been palettized (saved as GIF ???).
Both are JPG. This doesn't mean that the upper one couldn't have been a GIF at some time in the past. To be on the safe side and avoid loss by GIF palettization or JPG artifacts, save your images as PNG next time :-)
Xanderway
Post by Xanderway »
The picture was taken by my camera and the format is JPG.
When I opened it in XnView, I found the effect is different from that in windows explorer. The first picture which has been pasted above is the screen shot in XnView. The second one is in windows explorer. It has nothing to do with the format. All the screen shot was taken in the format of JPG.
Xanderway
Post by Xanderway »
Now, I paste the original picture on the web. Pls download it, then open it in XnView and windows explorer seperately.
Can anyone see the difference?
DOS386
Post by DOS386 »
Try this one. Use PNG or BMP format for the screenshot.
> Pls download it
Done!
> in XnView
Done! No problem. :-)
NOT done, I won't touch this one, sorry. :-(
marsh
Post by marsh »
Oh. JavaScript is required to download photo. A GIF is subsituted otherwise.
Xanderway wrote:When I opened it in XnView, I found the effect is different from that in windows explorer. The first picture which has been pasted above is the screen shot in XnView. The second one is in windows explorer. It has nothing to do with the format. All the screen shot was taken in the format of JPG.
Where do you see a difference?? i have the same view....
Xanderway
Post by Xanderway »
I have found the reason. :D
The reason is that the quality of screen is set to a lower setting.
If the property is set to highest setting, the picture looks same in XnView and Explorer. :mrgreen:
But I still wonder why the effect of explorer is better than that of XnView in lower setting of screen property.
