view blp file error
rswa
view blp file error
Post by rswa »
I Love Xnview. it's very convenient.
Recently,I use it to see blp file.
first file:
I cannot see the blp file http://www.mediafire.com/?by57wub0qld3tkf
second file:
I see the blp http://www.mediafire.com/?b4et9m8lea2h24b
it's bluish.
View In XnView
I convert the image from others converter
correct image
Re: view blp file error
rswa wrote: first file:
Could you post the converted image?
second file:
it's bluish.
Ok, i'll check...
rswa
Post by rswa »
thanks your response
this is first converted image
when i convert first blp to tga by other converter,
the converted image cannot be saw on xnview ,too.
but i can see the image by others (ex:photo impact,Picture Viewer)
http://www.mediafire.com/?1qssxgko1sxas42
rswa wrote:but i can see the image by others (ex:photo impact,Picture Viewer)
Which TGA? This one?
rswa
Post by rswa »
yes.. it is ...
rswa wrote:yes.. it is ...
I have no problem. Do you have desactivated alpha channel?
rswa
Post by rswa »
sorry... (I don't know this function..)
i do it ... i can see the converted tga picture now...
thanks...
