Hi
why can't i edit IPTC data on my canon raw files?
i can i do with jpg files
is there an option to enable?
i guess xnview could use exiftool that can do it
thanks
cheers
why can't edit IPTC data on my canon raw files?
drugo
drugo
Re: why can't edit IPTC data on my canon raw files?
nobody can help me?
i did a search , did not find an answer
thanks
thanks
- Forum Librarian
Here's what I've got:
- Canon RAW: Combine .CRW and .THM files
- IPTC dans des CR2 et fonction Recherche IPTC
- Cannot create IPTC metadata for RAF and CR2 files
- How to configure XnView to read data from XMP file?
- XnView crashs when reading IPTC data in Batch Rename (CR2)
- Set IPTC field with Batch Rename? ObjectName vs Headline
drugo
thanks a lotXnTriq wrote:Here's what I've got:
in short it doesn't work with canon raw files,does it?
it could write a xmp for the canon raw file (*.cr2)
thanks again
drugo
thanks again but XnViewMediaDetector can do it wiht my raw files , it's weird ,isn't ? maybe the Xnview author could help meXnTriq wrote:Here's what I've got:
thanks
??? No XnViewMediaDetector can't edit RAW files...drugo wrote: thanks again but XnViewMediaDetector can do it wiht my raw files , it's weird ,isn't ? maybe the Xnview author could help me
drugo
but does save xmp filesxnview wrote:??? No XnViewMediaDetector can't edit RAW files...drugo wrote: thanks again but XnViewMediaDetector can do it wiht my raw files , it's weird ,isn't ? maybe the Xnview author could help me
instead xnview doesn't
No, XnViewMediaDetector doesn't save XMP filedrugo wrote:but does save xmp filesxnview wrote:??? No XnViewMediaDetector can't edit RAW files...drugo wrote: thanks again but XnViewMediaDetector can do it wiht my raw files , it's weird ,isn't ? maybe the Xnview author could help me
