In my case Ctrl-Alt-A (Acquire) is not working (nothing happens). Call via menu items works as expected.
v1.97.6
Ctrl-Alt-A (Acquire) hotkey is not working
Re: Ctrl-Alt-A (Acquire) hotkey is not working
Strange, on which OS?
dma_k
I am also surprisedxnview wrote:Strange, on which OS?
OS: WinXP SP3.
dma_k
I have upgraded the system and the software.
Win7 Ultimate, XnView v1.97.8 – the same problem. It looks like it depends on Scanner Software (I have "CanoScan LiDE 100" scanner)?
dma_k
I have found the problem. There was a "global" key combination LCtrl+Alt+A defined by KeePass. After this hotkey was removed in KeePass, it started to work OK in xnview.dma_k wrote:I am also surprisedxnview wrote:Strange, on which OS?All hotkeys I tried work absolutely OK (Ctrl-P, Ctrl-O, F12, ...), but this is the only one not working. I suspect that some program is capturing it... but I really don't know how to find that spy
It is definitely not a keyboard layout change key.
OS: WinXP SP3.
