Delete files via shortcut w/o warning
MortenMacFly
Post by MortenMacFly »
I am doing a lot of pictures. I often face the situation, where I jump through the photos (at full size) and would like to remove (really delete physically) photos with bad quality. In XnView there is no easy way to do it - you have to use the menu and even then there comes a query if you are sure. While this is perfectly OK as deleting images is really something you probably don't want in my situation it is pretty annoying.
I would love to see a shortcut for deleting images and making the query "Are you sure" to remember my answer and thus being optional.
Probably this is already possible - in that case I'd like to hear how, of course... ;-)
