"New text file" option in browser right click menu?
ghost zero
Post by ghost zero »
In addition to the "new folder" option in the browser right click menu, can we also have a "new text file" option? This is very frequently used when adding notes to folders.
Re: "New text file" option in browser right click menu?
"New text file" for an image browser :-P
ghost zero
there is new folder function, so why not a new text file function? its good for adding notes for images collected inside a folder...
oops66
Post by oops66 »
ghost zero wrote:there is new folder function, so why not a new text file function? its good for adding notes for images collected inside a folder...
Why not, sometimes a simple text file can be useful too (instead using the meta-data).
In this case, why not using automatically the existing function under : "Create\File Listing" ...(Shift+L) by selecting before the entire folder (all files) then saving the file into this folder ?
Dreamer
Post by Dreamer »
I disagree, perhaps as menu option, or shortcut, but not in the right click menu, I'd rather remove some items from this menu. Just my opinion!
Dreamer
budz45
Post by budz45 »
It's really not necessary.
ghost zero
but useful and convenient to have
ghost zero
would still like to see this added. useful for puting notes along with folders of images.
Hmm, I can see that this feature would be helpful for you, ghost zero. But at the moment I don't see the standard use case, here:
The user can add descriptions to any file (Edit > Description/Comment...) or shortcut Ctrl+D. The description is stored in a separate file 'descript.ion' and can be applied for all files, regardless whether they support metadata or not. And for files with metadata support (JPEG) you have the metadata and description will be stored, there.
ghost zero
i prefer the use of simple .txt files
Ctrl + RMB on a file in the thumbnail panel brings up the shell context menu. Implementing this shortcut for the background of the panel would allow the user to access the New submenu from inside XnView.
ghost zero
but that still doesn't enable the creation of .txt files.
would be useful to also allow CTRL+RMB on blank area.
