Hello
I use the viewer from XnView since some weeks. Sometimes it hangs/crashes when I open the viewer (strg+B).
I figured out that the viewer always hangs when there is a pdf-document in the active directory.
In that case XnView is not responding and I must close it.
When I move the pdf out of the directory XnView works well.
It happens with an old version from 2007 and with the actual version 1.97.8.
Is it a bug or a feature?
Viewer hangs/crashes by PDF
- Forum Librarian
Re: Viewer hangs/crashes by PDF
Are the PDF-XChange shell extensions installed on your system?
xntest
Thank you.
Yes I had installed it.
I have uninstalled it and now XnView works fine in browser mode.
Is it possible to let show XP SP3 pdf-thumbs without hanging XnView?
- Forum Librarian
- FAQ: How to display vector formats like PDF, AI,...? GhostScript!
- Thumbnails for PDF, AI, EPS, ...?
- Empty thumbnail for PDF files
- PDF thumbnails and preview problems
- PDF thumbnail not working in Windows 7 64x with Ghostscript
- Thumbnails for: .PDF, .FLA [Flash], .AI [Adobe Illustrator]
- Tools » Options... » Browser » File List » File List
- Show item in view 'Thumbnails'
- AI, PS, PDF files [×]
