Auto Brightness in batch mode?
schimmerlos
Post by schimmerlos »
Is there any possiblity to use the "Auto Bright" feature in Tools > Batch mode?
I use the german version - It's called "Helligkeit automatisch einstellen..." and I want to use it within "Werkzeuge > Stapelverarbeitung"
Re: Auto Brightness in batch mode?
do you means auto levels?
schimmerlos
xnview wrote:do you means auto levels?
Yes, that's it. It is translated in two different ways to german:
In single image view: "Helligkeit automatisch einstellen..."
In batch processing mode: "Automatischer Farbabgleich"
Thanks!
From what I can see, the two string constants are:
TXT_NviewMenu_Auto_Levels
TXT_String_Auto_Levels
I've just corrected "TXT_String_Auto_Levels".
