Hi, red eyes correction works great but... jpg files are half or less its size everytime i use it.
Is there a way to keep quality (size) when using red eyes correction?
Thanks.
Red Eyes Correction and quality loss
Re: Red Eyes Correction and quality loss
option/Read-write/Write/Jpeg>Jpeg quality
yerg
Thanks!
So i slide quality bar up to 100 and it should work but... it actually makes it bigger in size (i do not mind).
what about "use estimated original quality if possible"? I googled it and only 2 results found. should i mark it? i tried it to keep original size but it does not...
- Forum Librarian
yerg wrote:what about "use estimated original quality if possible"? I googled it and only 2 results found. should i mark it? i tried it to keep original size but it does not...
