Hello XnViewers
I'm exploring this really useful looking program and have a query about customizing it to my use: how can I change the default toolbar?
> Tools > Options > Interface > Toolbar & from there I can delete or move icons. Bot I can't find a way to save the settings and it defaults back to Default toolbar when I close the pref. panel. I've seen screenshots posted re. other toolbar queries which have Load and Save buttons. These aren't present in the Vs. I'm using - 1.97.8.
Any help would be very welcome,
Best,
MO
XP Pro SP3
change default toolbar
Peter2
Re: change default toolbar
And APPEND buttons ...mob wrote:...> Tools > Options > Interface > Toolbar & from there I can delete or move icons. ...
Press APPEND - a placeholder will be added - select a command from the dropdown-list which will replace the placeholder. Use the > and < Buttons to move the icons..
Peter
mob
Thanks Peter, that's a new feature for me. But this one too doesn't 'stick' - there's no button to Save the changes and closing the panel defaults the Toolbar back to the Default as before.
MO
Peter2
Attention: Above the icons there are three buttons "Basic / View / Browser". Therefore you have to be careful which button is active and which toolbar will be edited ...
Peter
mob
So obvious it was staring me in the face! Thank you so much Peter,
MO
MO
Thanks for the good support, Peter.
Perhaps time for a FAQ...
