MP 0.35 Linux : Search using database fails
mahikeulbody
Post by mahikeulbody »
I cannot find anything if I set databse option into Search windows.
I am almost sure that the folder where I am searching is cached (I checked it with SQLite Browser, into Images table).
Re: MP 0.35 Linux : Search using database fails
What do you search? Perhaps you can send me some samples files to test?
mahikeulbody
For exemple, I tried to search 'date taken' exif field. I tried also to search xmp.city field. The search is ok (and very fast) if I unset 'database' option. The same search fails if I set 'database' option.
mahikeulbody wrote:For exemple, I tried to search 'date taken' exif field. I tried also to search xmp.city field. The search is ok (and very fast) if I unset 'database' option. The same search fails if I set 'database' option.
Could you send me 1 or 2 files that you use?
