RC4: Preview disappears after dbl click on Preview
Dreamer
Post by Dreamer »
Preview disappears after dbl click on Preview in the Browser (to go to Viewer) and dbl click on image in Viewer (to go back to the Browser) - only if you don't switch the images in Viewer. Dbl click on thumbnail works good.
ckit
Re: RC4: Preview disappears after dbl click on Preview...
Post by ckit »
Dreamer wrote:Preview disappears after dbl click on Preview in the Browser (to go to Viewer) and dbl click on image in Viewer (to go back to the Browser) - only if you don't switch the images in Viewer. Dbl click on thumbnail works good.
For me, the preview doesn't disappear instead another image is displayed in the preview pane while the original image is still selected. Another focus problem I think. Lite-fullscreen mode is disabled.
Bug #1 confirmed twice :bugconfirmed:
You have LMB as "Browser-Full/Edit-Full", and the problem is when you dbl click on preview? I can't reproduce it??
ckit
Post by ckit »
No I have LMB as "Edit mode and Browser" and the problem is when you dbl click on preview and then dbl click again to go back, the image has changed.
Dreamer
Post by Dreamer »
ckit wrote:No I have LMB as "Edit mode and Browser"
Right.
Sorry i would like to say that :-) But i can't reproduce that. I've always the old picture in preview...
Dreamer
Post by Dreamer »
xnview wrote:I've always the old picture in preview...
...ckit has wrong picture and I have no picture in preview :P
OK, try to reproduce my bug:
- default settings (probably not important)
- LMB dbl click to switch between "Edit mode and Browser"
- go to browser
- dbl click on preview (not on thumbnail)
- dbl click on image in viewer (don't switch images first!)
= there is no image in preview window
ckit
Post by ckit »
I can't re-produce your bug.
Heres how I tried it:
1. LMB dbl click to switch between "Edit mode and Browser"
2. In XnView, Browser mode
3. Select a file (only single click)
4. dbl click on preview (not on thumbnail)
5. dbl click on image in viewer (don't switch images first!)
6. XnView chooses some other image to show as preview!
Update!!!
I can fix this bug, by disabling "Synchronize Browser selection with current view"
Danny
Post by Danny »
- go to browser
= for me also the first file in the folder is shown in the preview area of the browser but the file i dbl clicked on is still selected (just like ckit described it). The same happens if you close a tab with the mdl mouse btn.
Funny thing is, if you use the middle mouse button to switch between edit mode and fullscreen it works when you click on the browser's preview area.
Another problem and how to reproduce it:
- Set up the middle mouse button to switch between edit mode and browser
- open browser and mdl click on a thumb (or file) and it will jump to edit view as expected
- if you now mdl click on this edit view mode, you will keep switching back and forth between the edit mode and fullscreen though - instead of switching between edit mode and browser. So you can't get back to the browser without closing the tab.
- and if you do close the tab manually the other problem re-occurrs: the first file in the folder will be displayed in the browser's preview area instead of the selcted file.
Dreamer
Post by Dreamer »
ckit wrote:Update!!!
I don't have "my" bug now (with my old .ini file), I had "Synchronize..." option always enabled, strange...
[ But I still have "my" bug with default options, ckit, try to reproduce "my" bug with default options please. ] - never mind, please wait for my ne post...
ckit
Post by ckit »
No sorry, even with a new INI file I can't re-produce your bug.
Danny
Post by Danny »
Yes, me too. But shouldn't it actually be the other way round? I still have my mdl mouse button mode switching problem though.
Dreamer
Post by Dreamer »
ckit, I can reproduce your bug now.
I have skipped one step I did, try again please (sorry)
- default settings
- options > browser > file list > Items shown in thumbnail mode - mark [x] Folders
- in the browser go to any image - don't use the folder tree!
Bug #2 confirmed once :bugconfirmed:
ckit
Post by ckit »
No I still can't re-produce the bug....
I will keep re-trying though :)
Dreamer
Post by Dreamer »
ckit wrote:No I still can't re-produce the bug....
Never mind, let other users try...
If Pierre will fix your bug (confirmed by me and Danny), maybe he'll fix also my bug somehow...
Locked
