Convert Slide Show back to images?
stormy_weather
Post by stormy_weather »
Is there a way to convert a slide show (.exe) file back to individual images?
I hope there is - but I fear there is not...
Thank You for your support!
Regards,
Sven
Re: Convert Slide Show back to images?
with which version do you have created it?
With 1.97, you can press E to save pictures
stormy_weather
One of the previous versions, unfortunately - because "E" does not work.
Regards,
Sven
if you send me the exe, i can extract them...
stormy_weather
Thank you for your kind offer!
I will write a PM.
Regards,
Sven
