xnview gets tired - doesn't display images 100% size
obelisk
Post by obelisk »
If i'm browsing a folder with 400 NEFs, viewing fullscreen, deleting, moving around, xnview eventually gets tired and:
:bugconfirmed:
doesn't rotate files
loads image at about 20% size - and calls it 100%
loads even smaller and my 12MP file is shown at about 200x400px
it never recovers and you must restart
:evil:
marsh
Re: xnview gets tired
Post by marsh »
Memory can run out if multiple images remain open (listed in Menu... Window).
With settings:
'Menu... View>[ ]Tabs'
'Options... View>[ ]Only one window view opened'.
obelisk
Post by obelisk »
Config is WinXP, 3GB ram.
I switch between fullscreen & browser only
there are no other tabs
sounds like a memory leak then
marsh
more detail?
Post by marsh »
I don't recall another similar post. If changing second option above isn't effective, perhaps disabling read ahead cache is worth trying.
Do you use 'read ahead'?
obelisk
Post by obelisk »
Yes I have read ahead
and without?
obelisk
Post by obelisk »
I can confirm now, after the error, turning off one or both cache options, it continues to read the image wrongly
obelisk
Post by obelisk »
contines to happen
it was better for a while but sorry now I have even larger MP files
now with 20-40MP files it happens after only a few views
even tho much faster machine 64bit and 8GB ram
You have only 1 image view?
obelisk
Post by obelisk »
It is now very repeatable.
I have folder with D800 raw, 36MP 40MB each.
Total about 200 files.
Start XnView in that folder. View fullscreen. Use pgdn to go next.
Sometimes use pgup to compare back. Sometimes press del while fullscreen.
Guaranteed after about 50 files, the issue occurs.
Do you use Read ahead/Cache behind?
obelisk
Post by obelisk »
Yes I do.
And I notice it's OK full screen, but in viewer mode is very slow.
In full screen if image is incorrectly rotated, then exit to browser then full screen again will fix it. Maybe it's still shrunk like before but 36MP is very big so still fills screen.
Anyway now I always restart xnview every 40 pics viewed.
obelisk wrote:And I notice it's OK full screen, but in viewer mode is very slow.
Fullscreen (F11) from browser?
obelisk
Post by obelisk »
I have fullscreen<->browser as 'Enter'
and viewer as middle click
