ImageShack plugin doesn't upload .PNG files...
ghost zero
ImageShack plugin doesn't upload .PNG files. Can this be fixed?
Re: ImageShack plugin doesn't upload .PNG files...
I don't understand why it don't work with PNG files
Peter2
I have other problems with Imageshack (-plugin)
From my office I can not upload with the plugin, and last week I could not upload using the Standard(!)-Imageshack-Website. http://imageshack.us/
But on the side I found a link: "Can't upload? Try this ...."
http://imageshack.us/?no_multi=1
There I could start another Imageshack-side, and it worked fine.
Now the question:
Which feature is used by the plugin?
Is there a way to change the target-sides of Imageshack?
Regards
Peter
Now the question:
Regards
Peter
