is it possible to create his own screen layout?
hmiller
Post by hmiller »
is it possible to create his own screen layout? Or can I just use the predefined ones? I would like to have the preview AND the EXIF-data (or the IPCT data) visible in two different windows. Is this possible?
best regards,
Harald
Moderator & Librarian
Re: is it possible to create his own screen layout?
Hello Harald,
I don't think there's a way to make XnView v1.9 display both the preview tab and the EXIF/ITPC panel side by side.
You may want to give the latest beta of XnView MP a try: View » Layout » Free.
XnView does not support arbitrary layouts, but the existing layouts can be tweaked and perhaps also your needs can be fulfilled.
By clicking the small min/max arrows in the pane separator you can see the preview either as seperate area/pane or as tab. When viewing as seperate area/pane you can see preview and EXIF data at the same time.
You're right, helmut. I should've known better.
