Thank's
slide show Photo adapted to the resolution of the monitor?
FlyAway
I have many photos with different resolutions, I would like to see which are nice to bring the resolution of my monitor (1920x1080) I thought of using the slide show but it haven't the function for show the image adapted to the monitor resolution
Thank's
Thank's
Re: slide show Photo adapted to the resolution of the monito
Do you have enabled 'Stretch small pictures'?
FlyAway
and small image are not fitted to your screen??FlyAway wrote:yes
FlyAway
FlyAway
the latest (portable)
1.98?FlyAway wrote:the latest (portable)
FlyAway
Could you send me the .sld file, and a picture not fitted?FlyAway wrote:Yes, 1.98
FlyAway
I haven't find the .sld file so I have post the full program, in the rar file I have put a folder named "picture not fitted" with some image. Thank's
http://www.megaupload.com/?d=RK4TDBQ1
No i means, that in slideshow you can save a file .sld
FlyAway
xnview wrote:No i means, that in slideshow you can save a file .sld
ok, Can you see the file that I have post and tell me what have incorrect? Thank's
But you have sent me XnView folder, not an image + sld fileFlyAway wrote:ok, Can you see the file that I have post and tell me what have incorrect? Thank'sxnview wrote:No i means, that in slideshow you can save a file .sld
marsh
