EMF support.
markusb68
EMF support.
Post by markusb68 »
can you please check this attached EMF file?
It seems that XnView does not render it correctly. (and all my other EMFs with bigger pictures inside too)
When I use "Windows Picture and Fax Viewer it looks O.K."
http://measmar.me.funpic.de/Folie1.zip
I have attached a JPEG how it should look alike:
Bigger one:
http://measmar.me.funpic.de/Folie1.JPG
I'm using the latest Version 1.98 on a German XP-Pro SP3
Thanks
Markus
Re: EMF support.
Yes, strange. Many viewers can't load it correctly too
markusb68
Re: EMF support.
Post by markusb68 »
They are generated by Powerpoint 2003 (all patches installed) using "save as" EMF.
I have to use EMF because PP can't export JPG in a reasonable quality. EMF is O.K. and so i want to use XnView to convert to JPG.
Do you have any plans to fix it?
Re: EMF support.
markusb68 wrote:Do you have any plans to fix it?
I'll try
markusb68
Re: EMF support.
Post by markusb68 »
Merci !
Peter2
Re: EMF support.
Post by Peter2 »
markusb68 wrote:...I have to use EMF because PP can't export JPG in a reasonable quality. EMF is O.K. and so i want to use XnView to convert to JPG.
Try free PDFCreator to print JPG, TIF, BMP, ...
http://www.pdfforge.org/
Peter
markusb68
Re: EMF support.
Post by markusb68 »
Sure may work. But scaling is a hassle and I haven't found a way to convert 140 slides in a row.
PDFCreator only exports ONE Jpg even if PP sends more than on "pages".
Peter2
Re: EMF support.
Post by Peter2 »
markusb68 wrote:...PDFCreator only exports ONE Jpg even if PP sends more than on "pages".
Print to some multipage-format (TIF, PDF, ..) and convert later?
I don't know, just guessing around ...
Peter
eL_PuSHeR
Re: EMF support.
Post by eL_PuSHeR »
I have tried opening this EMF file under some viewers and all of them fail. PMView says there is a CRC32 error while loading. Is the image okay?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
Peter2
Re: EMF support.
Post by Peter2 »
Try to download again. For me the ZIPs where OK.
Peter
markusb68
Re: EMF support.
Post by markusb68 »
HI,
the zip is ok. and the emf also. Try Windows XP's FAX and Image viewer.
eL_PuSHeR
Re: EMF support.
Post by eL_PuSHeR »
The ZIP is okay. Pmview issued the crc error while opening EMF. Possibly an error on PMview part. I do not have XP anymore. If you say XP's fax and image viewer works, then the EMF is okay.
Intel i7 5960X
8 GB DDR4 (2100)
