I have a windows batch file setup under Open With. In 1.98 if I activate it after selecting a large number of files only the first ten are passed to it.
In 197.8 XnView passed as many files from the selection as it could fit onto the command line
1.98: Open With not passing all filenames
Andrzej
Re: 1.98: Open With not passing all filenames
I have same problem : after command Open with ... Photoshop open only 10 pictures...
Right, i have changed that in 1.98
i'll fix it
Andrzej
Now - with 1.98.1 - i can open only 20 files... In 1.97 was"t limit.
Do you have a OpenWithMax in your .ini?Andrzej wrote:Now - with 1.98.1 - i can open only 20 files... In 1.97 was"t limit.
Andrzej
No, I have'nt
And if you add in [Start] section, OpenWithMax =100?Andrzej wrote:No, I have'nt
Andrzej
It's working, all is OK, thanks
