Error Copy Paste on some PNG
quillooo
Post by quillooo »
I can't copy (STRG+C) Paste (STRG+SHIFT+V) some PNG's correctly in 1.98.
They are displayed wrong, like you can see here:
On the left side the original image with the selected cut-out and on the right side the image pasted with STRG+SHIFT+V
- it's black/white
- a strange vertical line
- a strange dotted line bottom
Any suggestions?
Re: Error Copy Paste on some PNG
Could you send me the PNG?
quillooo
Post by quillooo »
You got a PM.
ok, i can reproduce...
quillooo
Post by quillooo »
And might there be a way to put things right?
i'll release in some weeks a 1.98.1, but i can send it to you if you want...
quillooo
Post by quillooo »
It's okay thanks, I've installed an older version meanwhile.
But I can approve the "Freezing on close", too.
Dmitry D.
Post by Dmitry D. »
Hello.
Can you reproduce the following:
I select an area, cut it, select other area, paste and get the shifted image.
source http://img339.imageshack.us/img339/3702/15431351.jpg
Imesh
Post by Imesh »
I have a problem with loading a PNG file. the program crashes when I load a PNG file..
I'm an Undergraduate and I love to learn
Imesh wrote:I have a problem with loading a PNG file. the program crashes when I load a PNG file..
johnny_fm
Post by johnny_fm »
Same problem with a shifted image while copy & paste, but I used a jpg:
quillooo
Post by quillooo »
Same in 1.98.1.
quillooo wrote:Same in 1.98.1.
you have always the same problem??? Could you resend the PNG?
quillooo
Post by quillooo »
I send you an email with 2 sample files and a little description.
It would be nice to hear, if it's possible to fix the problem, thanks :).
