1.98 Grayscale PSD files no longer load
jsXnv333
Post by jsXnv333 »
As of XnView version 1.98, grayscale PSD files no longer appear to be loading.
The same files load properly in the previous version 1.97.8.
I was able to reproduce the issue on a fresh install of XnView 1.98 on two different computers,
one running Windows XP Home SP3 (32-bit) and the other Windows 7 Professional (64-bit).
Sample psd file:
http://sharesend.com/e77lb
(If you can't download the file, let me know and I can email it to you.)
It should be a 200x200 pixel image of a vertical gradient from black to white.
When I try to open it in 1.98 I get a dialog that says "Error reading the file <graytest.psd>."
RGB and CMYK PSD files seem to load fine.
If I convert the above file to RGB and then save it in Photoshop, it loads correctly.
Re: 1.98 Grayscale PSD files no longer load
Yes will be fixed soon in a 1.98.1
Vapavite
Post by Vapavite »
confirmed !
Edit : Désolé, Thank you
Vapavite @+
jsXnv333
Post by jsXnv333 »
Thank you!
I'm looking forward to it!
