Convert Hemera .hpi to png/tiff/?? with alfa-channel/layer?
MacDuDe
Post by MacDuDe »
Helo and thanks for a realy great software :)
I'm a Mac-Osx user (latest ver.)
I'm trying to convert my Hemera image Catalog's to a Mac-friendly format (with alfa channel).
How do I do that? (I'm a novise and my english suc"#%) :)
The Hemera Fileformat is .Hpi -with alfa ch.
Re: Convert Hemera .hpi to png/tiff/?? with alfa-channel/lay
If you add your file in XnConvert, do you have a thumbnail?
MacDuDe
Post by MacDuDe »
xnview wrote:If you add your file in XnConvert, do you have a thumbnail?
Yes, all the images are visible in the XnConvert as thumbnails
I want to convert 100.000 .hpi images to alfa ch. compatible format (Mac)
I do not know how to use the XnConverter / it's settings to convert .hpi to other alfa-ch. compatible format.
There is nothing wrong with your software! (as far as i can tell)
