Preview is Empty
chris789
Preview is Empty
I couldn't pick the right words in search to find an answer to this question.
I have v1.98.1 and slecting a file in the main window produces nothing in the preview. I have options > Browser > File List > show in preview all checked. What else do I need to do?
Regards,
Chris
Regards,
Chris
Re: Preview is Empty
could you post a screenshot?
chris789
Out of curiosity, if I double click the Fullscreen icon rapidly twice, the preview pane displays the selected thumbnail!!
Regards,
Chris
Strange, Xp?
After installing it, you had preview?
chris789
Yes, XP. I have never had a preview when selecting a file in the main panel.
The preview is empty. I click once on the full screen view icon. I then hit esc. The preview is occupied.
Regards,
Chris
Regards,
Chris
Perhaps the same problem as in topic 'Lost my preview in Browser'?
chris789
Helmut,
You suggest from the link,
Regards,
Chris
From my first post above I said,Perhaps in menu "Tools > Options" | category "Browser > File List" you have unchecked the checkboxes in the column "Show in preview"
Haven’t I already done what you are now suggesting?I have options > Browser > File List > show in preview all checked.
Regards,
Chris
Could you try View>Preview Pane>Show?
chris789
I don't have View > Preview > Show. What I have is this,
I cannot select anything from real size to zoom in the second dialog box.
Regards,
Chris
Regards,
Chris
Not preview but Preview pane
chris789
Oops. You do have a lot of customisation choices!
Regards,
Chris
Regards,
Chris
Very strange, do you have tried to remove xnview.ini?
chris789
Pierre,
I have deleted the ini file two times and restarted XnView with no improvements.
I have emailed you my current ini file.
Regards,
Chris
Regards,
Chris
Hum, i've perhaps an idea....
Do you have the same problem with jpeg or png files?
chris789
PROBLEM IDENTIFIED?
Because we were running out of options, I tried a different folder. I tried my Pictures folder containg jpg's and any selected jpg had a preview.
Previously,the folders I have been using have all contained ace files. I obtained XnView to display multiple ace files at the same time - which it does magnificently.
Preview of jpg files works. Preview of ace files does not. I hope you, Pierre, can find the reason!!
Regards,
Chris
P.S. Telepathy of the same ideas at the same time??!!
Regards,
Chris
