Kodak Photo CD (.pcd)
fussy
Post by fussy »
I'm new to XnView - was pointed to it as a viewer for my Photo CD images.
.pcd files contain images of 5 resolutions. So far I've been able to view only the 768x512 resolution (middle level of the 5?). Is there a way to get XnView to display the other resolutions? (I'm especially interested in viewing the highest resolution)
crazytb
Post by crazytb »
Go to Option -> Read -> PhotoCD
But, unfortunately, I think only 3 resolutions are available. I don't know how PCD image works, but, if there are other resolutions, Pierre should know about it and should add support for them.
pcd!
Post by Guest »
well XnView can open the maximum resolution .. like you indicated, you can select the maximum one (base 64)
MAAD
crazytb
Re: pcd!
Post by crazytb »
Anonymous wrote:well XnView can open the maximum resolution .. like you indicated, you can select the maximum one (base 64)
It can??? Oh! XnView for Windows is much better!!!! Linux version only reads 3 formats:
  • Base (768x512)
  • Base/4 (384x256)
  • Base/16 (192x128)
I don't remember the Windows version options. I never used a PCD and I rarely use Windows. Could you post here the available formats for Windows?
Post by Guest »
what do you mean about "formats"..
here is the supported resolution of pcd..
base/16
base/4
base
base 4
base 16
base 64
if you need about the formats it support .. well it is a very large list..
MAAD
crazytb
Post by crazytb »
That was the info I wanted to know. I was talking about "PCD formats" or "sub-formats". Thanks.
Post by Guest »
Fine .. kodak is working on a newer version of PCD ..(still little info about it......)
MAAD
mrp
Post by mrp »
I use the v1.66 for WinXP of XnView. There just 3 sizes to open a Kodak PhotoCD (192x128, 384x256 and 768x512). If I use PhotoShop7 I can select between 6 sizes (64x96, 128x192, 256x384, 512x768, 1024x1536 and 2048x3072) I'm very interested to open files in the 2 larger sizes. /peter
mrp wrote:I use the v1.66 for WinXP of XnView. There just 3 sizes to open a Kodak PhotoCD (192x128, 384x256 and 768x512). If I use PhotoShop7 I can select between 6 sizes (64x96, 128x192, 256x384, 512x768, 1024x1536 and 2048x3072) I'm very intrested to open files in the 2 lager sizes. /peter
Do you have the pcdlib32.dll file in plugin folder? (See folder <installdir>\plugins or XnView menu "Info->Plugin information")
Regards. Pierre.
mrp
Post by mrp »
Thank You! After installation of the complete version, the plugin is present.. . /peter :D
