MP 0.38 Win: Some images NOT drawing in "Spotlight" -weird
budz45
Post by budz45 »
The majority of image files I have tried (lots) have worked just perfectly with "Spotlight" feature in drawing spotlight. I have even created spotlights on an 6870x5028 resolution pic :o (on my dual-core Win 7 machine) with normal results.
However, and this is weirdly, two pictures I load in XnView MP is not allowing me to create the actual spotlights (spotlight toolbar + functions display as normal) but spotlight cannot be drawn.
To reproduce,
download this .zip,
cantankerous little devils.zip
..extract and load either one of the two image files in MP and try to draw a spotlight with the selection
..and this is my xnview.ini settings file (just to be sure)
xnview.zip
Could the issue be related to the image dimensions/pixels, or could it be the specific colors or each picture.. hmmm
Good luck!
tested on both Win XP sp3 & Windows 7 sp1
Re: MP 0.38 Win: Some images NOT drawing in "Spotlight" -wei
Ok, the problem is when you use picture not 24bits
budz45
Post by budz45 »
xnview wrote:Ok, the problem is when you use picture not 24bits
Ok, that was nice to know :P
budz45 wrote: download this .zip,
Fixed in XnViewMP 0.38.1 :P
