v.0.38 Close other tab closes current tab
Choosing 'close other tabs' closes current tab instead.
Re: v.0.38 Close other tab closes current tab
Confirmed.
Also, closing the last tab doesn't close XnView even if Closing last tab closes XnView is set. I'm using Windows XP.
I think Pierre is working hard on the code to all these things, don't worry
In fact this topic issue could be related to these recently Fixed bugs of these (I may be wrong):
http://newsgroup.xnview.com/viewtopic.php?f=74&t=21538
http://newsgroup.xnview.com/viewtopic.php?f=74&t=21543
http://newsgroup.xnview.com/viewtopic.p ... 469#p95469 (blank window issue on closing last tab - fixed in 0.38.1)
So I of course I believe eventually will work together again and those tickbox settings that are not responding will get resolved.
Yes a bug, confirmed in 0.38.1marsh wrote:Choosing 'close other tabs' closes current tab instead.
I'm not able to reproduce this in MP 0.38.1 - I enabled the setting, then I closed last remaining tab on interface and it worked as normal (program exits with enabled setting). perhaps this might've been fixed in 0.38.1, Pierre will help you there.-g- wrote: Also, closing the last tab doesn't close XnView even if Closing last tab closes XnView is set. I'm using Windows XP.
fixed; v.0.38.2
