Convert window and Convert single file
lian
Post by lian »
the remarks of the day for MP 0.38:
- Ctrl+U opens a big window and the -bad- reflex is to close it... and close MP with it :-( The preious little window seemed me more ergonomic)
- no convert single file when right-clicking. Too bad.
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
Re: Convert window and Convert single file
lian wrote:- Ctrl+U opens a big window and the -bad- reflex is to close it... and close MP with it :-( The preious little window seemed me more ergonomic)
Which previous little window????
In browse mode?
lian
Post by lian »
xnview wrote: Which previous little window????
Sorry: the window in previous versions (XnView by example).
In browse mode?
Well, in every modes.
lian wrote: Well, in every modes.
You means like XnView 1.98, context menu>Convert into?
lian
Post by lian »
Yes. Sorry again for my imprecision (je ferai mieux de le faire en français...).
Peter2
Post by Peter2 »
lian wrote:....
- Ctrl+U opens a big window and ....
Yes, can confirm this behaviour:
- Ctrl-U opens the batch-conversion as a tab of the main-program, same size as the main-program.
- open the conversion with the mouse opens the converter as a "standalone, modeless" window.
Bug or feature?
Peter
Peter2 wrote:
lian wrote:....
Bug or feature?
Peter
:o Ctrl is used to open an experimental batch convert as a tab.... So yes, if you use the shortcut, you have a tab... Perhaps it's better to use another key like shift
JohnFredC
Post by JohnFredC »
I am the one who originally requested the tabbed Batch convert, and I really like it!
However, tab should not be the default mode for Batch (or at least not yet!)... so, [Shift]+"U" has my support.
(Or any other convenient/available hotkey.)
John
JohnFredC wrote: However, tab should not be the default mode for Batch (or at least not yet!)... so, [Shift]+"U" has my support.
I means Shift + batch convert to start it as tab :)
JohnFredC
Post by JohnFredC »
Yeh, that's what I meant... :|
John
