Pretty silently the Compare dialog has been introduced in RC4. Another nice new feature. But it needs a bit of fine-tuning, still.
The compare dialog is something that people might use often, so it should get a short cut. Perhaps Dreamer knows which shortcut can be used.
RC5: Compare dialog: Short cut
Yes, nice feature...
I suggest Ctrl+F10 (as secondary shortcut, because I use it often in my file manager
And primary... Shift+C ?
What about "Generate File Listing" - is there any shortcut for it ?
I suggest Ctrl+M (as secondary shortcut, also same as in my file manager - "Make file list").
And primary - Shift+L
Everyone agree with:Dreamer wrote:Yes, nice feature...
I suggest Ctrl+F10 (as secondary shortcut, because I use it often in my file manager).
Ctrl+F10 , Shift+C => Compare
Ctrl+M, Shift+L => file listing
