I wanted to convert a lot of big TIFF files to JPEG2000, but unfortunately all EXIF data get lost.
I was using XnConvert too and there is under "Option" --> "Preserve Metadata", but it doesn't preserve EXIF data.
I already searched this forum, but I only found this:
http://newsgroup.xnview.com/viewtopic.p ... xif#p67027
Is there any way to use a better format than TIFF or JPEG which saves the EXIF data too?
I just got the idea to export all EXIF data to a text file prior to the conversion but again unfortunately there is no such action in XnConvert.
Thanks
JPEG2000 and EXIF data
Re: JPEG2000 and EXIF data
No sorry, currently jpeg2000 encoder doesn't support metadata
XnViewUser
Hi Pierre,
thank you for your quick answer. Unfortunately I did not find any software which encodes to JPEG200 including EXIF data.
But as I found, JPEG2000 is the only format which compresses images lossless. Am I right?
Now I found the following solution for me:
1) I export all EXIF data into text file by using ExifTool.
2) Then I convert to JPEG2000.
What do you think to create an action in XnConvert to export EXIF data into a text file?
Best regards
P.S.:
XnView and XnConvert are really great pieces of software. I think there is nothing better out there. Many years I used IrfanView but then suddenly I found XnView and it is much better than anything else.
Best regards
P.S.:
Drahken
Nope. Although it does get some of the best compression when dealing with photographic images. I don't know if any of the other lossless formats handle exif data or not though (I never bother with metadata myself).But as I found, JPEG2000 is the only format which compresses images lossless. Am I right?
PNG is lossless of course, JPEG-XR also has a lossless mode (and gets almost as good compression as jpeg2000, but much faster). LWF has lossless, but it's a proprietary format, so it shouldn't really be used unless you have to.
MiKiL
There is one JPEG2000-encoder that preserves metadata including EXIF, Adobe Photoshop's JPEG2000-plugin that writes extended JP2-files. Only odd thing with this is that it seems to use it's own uuid-code so other programs doesn't recognize it, had to check it with hexeditor that it's all in there.
