Hello, I just need to convert .tif files into .png files and resize the canvas of these .png's. I need to do this from windows command prompt. I don't need the gui at all. I would like the simplest tool that works.
I thought nconvert http://www.xnview.com/en/features_nc.html would be perfect... but nconvert doesn't seem to have the functionality of telling me the input file width. I need this to know the resize % for the png.
Will XnView Convert do the job (from command line) or do I need something else?
Thank-you in advance, Michelle
Convert .tif to resized .png from windows command prompt
michelle
Re: Convert .tif to resized .png from windows command prompt
you would like to use original file width to make canvas resize?
michelle
thanks Pierre, but I have already gotten around this problem. I no longer need to do this. Thanks. Michelle
