exiftool cannot support UNICODE
wuxian1001
Post by wuxian1001 »
when I check exif of images,I fing that images with UNICODE filenames or paths cannot be recognised by exiftool.
Would you please make exiftool support UNICODE?
Re: exiftool cannot support UNICODE
Currently i don't know how to use exiftool with unicode filename :(
wuxian1001
xnview wrote:Currently i don't know how to use exiftool with unicode filename :(
I guess exiftool doesn't support unicode.
So would you use another tool to show exif?
Why you don't use EXIF tab?
wuxian1001
I use the exiftool tab.
Where's EXIF tab?
wuxian1001 wrote:Where's EXIF tab?
You have info, IPTC, EXIF, exiftool tab
wuxian1001
I check the EXIF tab in Info,but can't find it.
XnViewMP version 0.38.7
wuxian1001
I don't have such tab.
Leonidas
Post by Leonidas »
See http://www.sno.phy.queensu.ca/~phil/exiftool/#problems
ExifTool wrote:In Windows, ExifTool will not process files with Unicode characters in the file name. This is due to an underlying lack of support for Unicode filenames in the Windows standard C I/O libraries.
wuxian1001 wrote:I don't have such tab.
If you don't have EXIF tab, your file has no EXIF data
