xnviewMP 0.39 Windows
Resize/resample/keep ratio doesn't work ('keep ratio' is ignored).
However, if you enter the numbers by hand, it seems to work...
PS: I also noticed that drag n' drop doesn't seem to work in Folders. I know it doesn't in Favorites (though I think it should, it makes things much, much easier).
0.39MP / resize "keep ratio" is broken
tegehel
Cyril van der Haegen ▪ Illustrator
Website ▪ http://www.tegehel.org
Website ▪ http://www.tegehel.deviantart.com
Re: 0.39MP / resize "keep ratio" is broken
I can't confirm. When you use arrow??
