IMO the search results should be treated like an ordinary folder so you can handle the files in there just the same. At least that's how i'm used to it from ACDSee. Currently i can't start a Quick Slideshow from the files in a search result for example. That probably requires that it won't leave the search results until i click on some folder.
Maybe not in 1.8 though. That's up to you and how much work this would create.
1.81? REQ: Search results handling
Re: REQ: Search results handling
RightDanny wrote:IMO the search results should be treated like an ordinary folder so you can handle the files in there just the same. At least that's how i'm used to it from ACDSee. Currently i can't start a Quick Slideshow from the files in a search result for example. That probably requires that it won't leave the search results until i click on some folder.
Danny
Wow, great! Thanks!xnview wrote:Right
Danny
Dreamer
