Slide show text not working
timbooo
Post by timbooo »
Hi there,
I'm facing a problem that concerns a slideshow. If I display the slideshow or save it as an exe-file everything works fine: My filename is displayed at the bottom center with a background. However if I want to create a video of the slideshow (tried Divx and Xvid) the text seems not to be included, ergo missing.
Am I doing something wrong or missed some settings that concern the video creation?
Kind regards
Tim
PS: I'm using XnView 1.98.2 on Windows XP
Re: Slide show text not working
Yes, right, text is not added for video export
timbooo
Post by timbooo »
Hi, thanks for the fast reply.
Is there any chance in achieving this "feature" in any other way with XnView?
Tim
KrisR
Post by KrisR »
HI,
I am facing the same problem.
The 'Creating File Show' function is very useful for me and I use it quite a lot. I have used it to create a video file e.g. .wmv, from several hundred pictures,
and it works just great.
However, it would have been even more useful if it were possible to add captions to the pictures.
All the facilities for doing so seem to be there, however, regardless of what options I tick no text appears on my video.
I'm running the most recent version, v1.98.5, but still this problem does not seem to have been fixed.
Please fix it!
Best regards
KrisR
KrisR wrote:I'm running the most recent version, v1.98.5, but still this problem does not seem to have been fixed.
Ok, i'll try to add in a future version...
KrisR
Post by KrisR »
Greatly appreciated :-)
KrisR
