XnviewMP 0.39 Linux Crash
Roumano
Post by Roumano »
XnviewMP crash on load several pictures who have originaly problem with metada exif problem , gthumb software create this error :(
I was this kind of error before :
error: Bad format (0) for IFD0 entry 0.
exiftool IMG_7982.JPG | grep -i decision
Original Decision Data Offset : 3186
Warning : Invalid original decision data
I fix them with this command :
exiftool -all= -tagsfromfile @ -all:all -unsafe test.jpg
The exif diff before/after the fix :
diff ok.txt ko.txt
4,5c4,5
< File Size : 1082 kB
< File Modification Date/Time : 2012:01:02 08:09:31+01:00
> File Size : 1085 kB
> File Modification Date/Time : 2012:01:02 08:08:57+01:00
9c9
< JFIF Version : 1.02
> JFIF Version : 1.01
152c152
< Original Decision Data Offset : 0
237c237
< XMP Toolkit : Image::ExifTool 8.50
> XMP Toolkit : XMP Core 4.4.0-Exiv2
252a253
Error with xnviewMP :
## MyView::onLoaded </home/roumano/Images/2011 12 31 Reveillon/2011-12-31--17.43.24 - .jpg> </home/roumano/Images/2011 12 31 Reveillon/2011-12-31--17.43.24 - .jpg> </home/roumano/Images/2011 12 31 Reveillon/2011-12-31--17.43.24 - .jpg> (0)
## MyView::onLoaded ok
### resetViewport (1bd62b0) ==> 499 518 (499 332) 0 0
Create Tree : Fichier
Create Tree : Image
bug-buddy: /home/roumano/bin/XnViewMP-039/lib/libxml2.so.2: no version information available (required by bug-buddy)
bug-buddy: /home/roumano/bin/XnViewMP-039/lib/libxml2.so.2: no version information available (required by /usr/lib64/libebook-1.2.so.10)
bug-buddy: /home/roumano/bin/XnViewMP-039/lib/libxml2.so.2: no version information available (required by /usr/lib64/libsoup-2.4.so.1)
bug-buddy: /home/roumano/bin/XnViewMP-039/lib/libz.so.1: no version information available (required by /usr/lib64/libgio-2.0.so.0)
bug-buddy: /home/roumano/bin/XnViewMP-039/lib/libxml2.so.2: no version information available (required by /usr/lib64/libedataserver-1.2.so.14)
I have test to clear the configuration of xnviewmp, same problem ( mv .xnviewmp{,.old}
I can send a picture to test if needed
Re: XnviewMP 0.39 Linux Crash
yes please send me the picture
Roumano
Post by Roumano »
Je vient d'envoyer la photo par mail.
Cdt
Please check XnViewMP 0.48
