as reported by someone else at http://newsgroup.xnview.com/viewtopic.php?f=36&t=19519, sort by ratio (and folder) does not work. You answered that you can't reproduce it, so it's specific to some configurations/installations.
Let me know if I can help to reproduce.
I'm using XnView Portable from portableapps.com, version 1.98.5, but I tried with 1.98.2 and still no luck. OS is Windows 7 32bit Italian.
I want to sort to separate some images between vertical and horizontal.
Thank you
Sort by ratio doesn't work
Leftie
Re: Sort by ratio doesn't work
I'm having the same problem.
Running XnView version 1.99 English on 64-bit Windows 7.
What I'm experiencing:
Selecting View -> Sort By -> Ratio
The sorting in the browser window does not change, nor does the active "Sort By" item in the menu.
This still seems to apply to the "Folder" sort as well, but that's a different topic.
Kind regards
Leftie
Kind regards
Leftie
Ok, there is a problem with Menu>Sort by - Ratio, use mini toolbar to change sorting...
Leftie
Ok, that works perfectly.
Thanks for the quick reply
