1.98.8:a bug when label switching
ljziyue
Post by ljziyue »
If I open two or more pictures,I can find a dialog box flashed when label switching.
I have found this bug on many computers.
system:win 7 U
system language:Simple Chinese
xnview:1.98.8 or the previous versions
I sent two email to webmaster@<!-- removed* --> when the latest version was 1.98.6,and this bug has been confirmed.It's a problem with MDI window on windows.
But even now it hasn't been fixed.
Re: 1.98.8:a bug when label switching
You means when you change current tab? It's a problem in the windows API & MDI, so i can't fix it
ljziyue
Post by ljziyue »
xnview wrote:You means when you change current tab? It's a problem in the windows API & MDI, so i can't fix it
oh.Thanks for you reply.
ljziyue
Post by ljziyue »
In my opinion,although this problem with windows API & MDI can't be solved perfectly,but I think that the vast majority of people browse pictures with maximizing the child window.So you can modify the code to avoid this.
wish!
