Some suggestion for MP
BK201
Post by BK201 »
0. More customizable hotkey setting. Examples: Quit with Esc or alt-F4 is not changeable; "/" for image auto resize is not changeable, etc.
1. More customizable panel. Examples: Quick toolbar at the top of browser is not removable; Sub panels in information panel cannot be dragged out, etc.
bug report:
0. Cannot change back to default theme after select any of other themes.
1. Sometimes cannot remember the window size when closed.
2. GIF images frames looks weird if you watch step by step.
budz45
Re: Some suggestion for MP
Post by budz45 »
BK201 wrote:0. More customizable hotkey setting. Examples: Quit with Esc or alt-F4 is not changeable; "/" for image auto resize is not changeable, etc.
Yes these aspects should be customizable. I myself would like to configure "Esc" hotkey so that it does NOT close a view tab.
BK201 wrote:1. More customizable panel. Examples: Quick toolbar at the top of browser is not removable;
Hmm... Do you mean to have a toolbar right-click option, such as "Hide this toolbar" ? :P
BK201 wrote:Sub panels in information panel cannot be dragged out, etc.
Well the Information window itself is drag-able (as you might already know) however since the 'sub panels' you refer to are presented as tabs (e.g. properties, histogram etc) then it is going to be less imaginable having these as separate drag-able panels since all the "Information" window items have to be kept together uniformed. Might require a massive code rewrite by the developer if this was ever to happen. Sorry I don't support.
BK201 wrote: bug report:
0. Yes this is possible, just press "Default" and then restart XnView MP to see the change; http://i.imgur.com/OatRw.png
1. Window size always gets remembered :)
2. You could post an example GIF image here in this topic for us to see your issue.
BK201
Post by BK201 »
http://i.minus.com/ijQ1htVBFjJ9b.gif
How it looks like in steps:
Seems that MP only display the *changes* between two frame
No, it won't if you using edge maximize in win7 (a aero feature)
Fixed in 0.48
Doesn't care that anymore, I've enjoyed the new theme.
Sub panel *preview* can be dragged out and put anywhere else, while the other two *info* and *folders* can not.
I can not remove this.
