v0.48 Ratings are lost
soulky
After updating from 0.39 to 0.48 all ratings are lost.
Re: v0.48 Ratings are lost
You had with 0.39 only database rating?soulky wrote:After updating from 0.39 to 0.48 all ratings are lost.
soulky
Yes. I copied the 0.48 installation into the 0.39 folder. It is also redoing the thumbnails completely.
And you have kept the xnview.ini?
soulky
Yes. there was no xnview.ini in the 0.48 folder. So the original xnview.ini was kept.xnview wrote:And you have kept the xnview.ini?
And if you replace the xnview.db by your save, same thing?
You have not the 'Export rating in XMP metadata'?
With a clean db, i've made some rating with 0.39, start 0.48, and all is here...
soulky
I decided not to backupt the database as it was for testing only.
And now do you have problem with rating??soulky wrote:I decided not to backupt the database as it was for testing only.
soulky
How do you mean? There are no new problems with rating. But it was not possible to keep the rating when going from 0.39 to 0.48.xnview wrote:And now do you have problem with rating??soulky wrote:I decided not to backupt the database as it was for testing only.
I've made rating in 0.39, and start 0.48, all my rating are here...soulky wrote: How do you mean? There are no new problems with rating. But it was not possible to keep the rating when going from 0.39 to 0.48.
Could you try again?
