Opening a selection of files
CreativeWorld
Post by CreativeWorld »
What I would like:
There are 100 image files in a folder.
1. Select 3 of those files in Windows file explorer
2. Right-click, "Open" or "Open in XnView"
3. it opens a single instance of XnView and I can flip through the 3 files using the arrow keys.
4. Leaving that open, go back to file explorer
5. Select 4 files, maybe some the same as before, doesn't matter
6. Right click, "open" or "open in xnview"
7. another instance opens with those 4 files in it, and I can flip through them using the arrow keys
Is there some way to set this up using the settings?
"Only one Instance" is no good, because I can't do step 7. Without it, the files open up in separate windows. With it, a single file opens up in a single window and I am stuck flipping through all 100 files instead of only the 3 I selected.
Re: Opening a selection of files
you would like only 1 instance?
AEN007
Single Instance
Post by AEN007 »
13Octobre2013
allô ...
J'adore XnView, mais
XnV a besoin de "Single Instance" ...
Merci beaucoup ...
